[GRASS-user] v.to.rast "unknown use type"
Seb spluque at gmail.com
Tue Mar 20 23:08:59 EDT 2007
I'm having problems with the following call to rasterize a vector:
v.to.rast input=test output=test use=z type=point layer=1 value=1 rows=4096
The vector contains 1 minute gridded GEBCO bathymetry data, which I
imported with v.in.ascii, assigning depth data to the 'z' coordinate.
However, the call above gives the error message:
---<---------------cut here---------------start-------------->---
Converted areas: [0] of [0]
Converted points/lines: [329427] of [329427]
Unknown use type: 4
---<---------------cut here---------------end---------------->---
I'd greatly appreciate some clues on what may be going on.
Cheers,
Seb
