[GRASS-user] Encountering an error importing shapefiles with v.in.ogr
Thomas Adams Thomas.Adams at noaa.gov
Wed Mar 21 11:53:59 EDT 2007
Raffaele,
After further testing, I do see the same problem you have had,
namely,"(some) areas which are not available after using v.in.ogr." This
is very apparent if I randomly color the polygons — some do not get
filled. Also, if I do a v.to.rast conversion, I get holes in the newly
created raster.
Does anyone have thoughts on this?
Regards,
Tom
Raffaele Morelli wrote:
>     Cannot display areas, topology not available.
>     I am virtually certain that I was able to successfully import this
>     and
>     other shapefiles in previous versions of GRASS (GRASS 4.x & GRASS
>     5.x).
>     The shapefiles files include the *.dbf, *.shp, and *.shx files,
>     which I
>     think, should be enough. If I import shapefiles from the US National
>     Atlas (created by the USGS), I have no problems. It seems that
>     with all
>     shapefiles generated by my office using ArcGIS 9.0, I have this
>     problem.
> Similar problem with shapefiles generated using ArcGIS, I recently
> posted a topic about (some) areas which are not available after v.in.ogr.
>     Does anyone have suggestions as to what could be going on?
> Hamish suggested using 'v.in.ogr -c ' (does not clean polygons) which
> didn't worked for me.
> I partially solved using v.in.ogr without min_area and snap parameters
> but when patching adjacent shapes I do not some polygons lost area.
> Are you experiencing something similar with ArcGIS shapes?
> regards
> raffaele
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL:	thomas.adams at noaa.gov
VOICE:	937-383-0528
FAX:	937-383-0033
