[GRASS-user] Encountering an error importing shapefiles with v.in.ogr
Thu Mar 22 06:20:26 EDT 2007
Moritz Lennert wrote:
> You can try to rerun the entire cleaning operation that v.in.ogr uses,
> i.e.:
> v.clean in=inmap out=outmap_clean_vinogr
> tool=snap,bpol,rmdupl,break,rmdupl,rmsa,chdangle,rmdangle,chbridge,rm
> bridge thresh=0.000001
> and maybe play around with the thresh parameter, depending on your
> projection and data resolution.
Radim often made it known that 'v.in.ogr -c' + v.clean is not the same
as v.in.ogr's built-in cleaning.
Hamish
