[GRASS-user] Grass 6.3 on OS X
Thu Mar 22 06:33:03 EDT 2007
Richard Chirgwin wrote:
> Hi,
> In using the William Kyngesburye build on Mac OS X, I have a persistent
> problem with vector files. Even where I have built the vector inside
> Grass (for eg, by importing a shapefile such as the outline of
> Australia), there is a coor file problem. Step by step:
> 1) Start Grass
> 2) Import shapefile
> 3) Select new vector file
> 4) Display - OK.
> 5) Exit Grass
> 6) Restart Grass
> 7) Select vector file
> 8) Display
> At (8), Grass says the Coor files is larger than it should be, and asks
> me to rebuild the topology. It will not display the file. V.build
> doesn't fix the problem.
> Any suggestions?
at step 5, what is your exact method of exiting GRASS?
File->Quit and then "exit" in the terminal window?
were is your GRASS data stored? /Users/you/grassdata/ ?
try without the GUI? from the command prompt:
v.in.ogr out=<map>
v.info <map>
g.region vect=<map>
d.mon x0
d.vect <map>
Hamish
