[GRASS-user] Vector - thematic question
Richard Chirgwin rchirgwin at ozemail.com.au
Fri Mar 23 18:12:12 EDT 2007
Thanks for all the previous help! - I am getting to a point where I am
feeling nearly competent.
I am now nearing the tasks for which I first started working with
Grass-GIS. It involves working with multiple tables to create a thematic
map, and it's the linking that's busting my brain.
I have:
- A map of Australia as a boundary, with locations as boundaries, and a
numeric index of locations (vector 1), in a DBF (it was imported from a
Geosciences Australia shapefile).
- A points file of locations within the boundaries as
latitude/longitude, with the same numeric index identifying which
location the points fall within (vector 2). This file is on a MySQL DB,
with a "total" column showing the number of locations in each index number.
What I want to do is use the "total" column in vector 2 to colour vector
1 as a thematic map. What is the best way to create this link?
Cheers,
Richard Chirgwin
