[GRASS-user] Maximum number of GRASS files within a mapset?
Sat Mar 24 03:51:23 EDT 2007
Shaun wrote:
> I seem to be running into a GRASS limitation relating to the maximum
> number of rasters available within a single mapset location, which
> appears to be exactly 32000.
Paul:
>> I fear it may be a Unix limitation - the maximum number of files
>> in one directory.
Amaginary Studios wrote:
> wow, that's a massive amount of seperate rasters! I suppose
> unfortunately the only answer I can offer would be to create another
> mapset,
yeah, try creating a new mapset to put new maps in, then add the
previous mapset(s) into the map search path with the g.mapsets module
(with an "s").
even if a mapset is not in the search path, you can still access it with
"mapname at othermapset".
Hamish
