[GRASS-user] 'where' sql command in d.vect and others
Seb spluque at gmail.com
Sat Mar 24 09:46:32 EDT 2007
On Sat, 24 Mar 2007 08:35:56 -0500,
Seb <spluque at gmail.com> wrote:
> but it's not subsetting as expected.  Is this the right syntax for
> constructing the 'where' parameter?
I think this is a quoting issue.  The data look like this:
db.select communities
cat|str_1|str_2|str_3|dbl_1|dbl_2|int_1
1|"312"|"East Whitefish"|"W Arctic"|||58
Does the double quote need to be escaped somehow?  Thanks.
Seb
