[GRASS-user] Problem with slope modeling .
Amaginary Studios amagine at telus.net
Sat Mar 24 22:39:22 EDT 2007
I was looking at your image you linked too of your DEM with slope
profile.
I am really confused by your Isolines....
The profile you drew on your DEM shows exactly what you would expect
from your transect along the DEM colour sensitive elevations.
The Isolines however are completely contradictory.... but... Maybe
these isolines are for something entirely else besides elevation?
Sorry, can't wrap my head around what those isolines are representing...
When you say:
> I expect that the slope between two isolines on the bottom of the
> valley will be similar.
I presume the Isolines are representative of Elevation.
If the Isolines are representative of Elevation then what is the DEM
representative of?
Your profile is of your Raster image, and your transect profile along
that image shows a fairly constant elevation with the slight dips
that are represented in your Profile graph.
Meanwhile the isolines are telling a completely different story....
Is there any chance that one of your fields inputted was mixed up
between slope and elevation, that your DEM is perhaps incorrect?
I am used to seeing similar colours ALONG the length of the Isolines
not Against them.
Maybe I'm way out in left field picking daisies... I don't know...
Nice snapshot thought!
good luck!
Mars
On 24-Mar-07, at 1:03 PM, Radomir wrote:
> Hi all,
> I'm preparing the slope and elevation map from digitised isolines.
> I'm using v.surf.rst to do that with the following options:
> v.surf.rst input="izolinie_punkty" layer=1 zcolumn="wysokosc_m_npm"
> dmax=3.174812 dmin=0.634962 elev="mapa_wystaw" slope="mapa_spadk"
> maskmap="maska" zmult=1.0 tension=40. segmax=40 npmin=300
> The screenshot from small part of resulting map is here:
> http://mort.no-ip.org/screen.png
> On this screen you can see the valley in the center. I expect that the
> slope between two isolines on the bottom of the valley will be
> similar.
> But it is changing and gives an effect of "wave" between isolines.
> Those
> "waves" cause the unexpected results in LS factor.
> I was trying to manipulate with the tension and smoothness but without
> visible results.
> What should I change to calculate better slope model?? Any help with
> understanding will be appreciated.
> Best Regards,
> Radomir
> Radomir
> The Future Is Now ;)
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
Amaginary Studios
Phone 250 845 7999
Mars Sjoden
3320 Mount Davis Way
Houston BC
V0J 1Z2
READ CAREFULLY.
By reading this email, you agree, on behalf of your employer, to
release me from all obligations and waivers arising from any and all
NON-NEGOTIATED agreements, licenses, terms-of-service, shrinkwrap,
clickwrap, browsewrap, confidentiality, non-disclosure, non-compete
and acceptable use policies ("BOGUS AGREEMENTS") that I have entered
into with your employer, its partners, licensors, agents and assigns,
in perpetuity, without prejudice to my ongoing rights and privileges.
You further represent that you have the authority to release me from
any BOGUS AGREEMENTS on behalf of your employer.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070324/735516ec/attachment.html
