[GRASS-user] help setting the color of DEM
Jachym Cepicky jachym.cepicky at gmail.com
Mon Mar 26 04:26:16 EDT 2007
to change colors of raster map, you need to use r.colors. Several
predefined color tables are available, "elevation" and "terrain"
between them.
To display satelite image on the elevation map (or to get "plastic"
feeling of a satelit image), you can use:
1)  shaded relief map
r.shaded.relief map=elevation shadedmap=shade
d.his h=satelite i=shade
2) nviz module
nviz elev=elevation color=satelite
hope it helps
jachym
2007/3/26, nishith datta <nkdiitd2002 at gmail.com>:
> hi all,
> Thanks to the forum and all the help we keep getting from you all.
> I recently gtot through with generating a DEM using v.surf.rst . I donot
> have any say on the colors.
> The colors are bright green , yellow ..... Could I change it to something
> better.
> Do i need to do it at the elevation raster lever ?
> Another issue is how to drape a satellite imagery on the DEM....
> Thanks
> nishith
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
