[GRASS-dev] Re: [GRASS-user] 'where' sql command in d.vect and others
Moritz Lennert mlennert at club.worldonline.be
Mon Mar 26 04:55:34 EDT 2007
On 25/03/07 18:43, Seb wrote:
> On Sun, 25 Mar 2007 17:08:08 +0100,
> Glynn Clements <glynn at gclements.plus.com> wrote:
>> gis.m doesn't use monitors, so you can't use d.save on the gis.m
>> displays.
> Is there some analog for d.save in gis.m?  I started getting more
> acquainted with gis.m and another thing I'm struggling with is placing
> legends and scale bars outside of the region.  Is this somehow possible,
> or should I stick to d.m for this?  Thanks again.
You can save the content of your map display by clicking on the little
floppy disk button (fourth from the right) and choosing the format you
want to save your map as. Is this what you are looking for ?
Moritz
