[GRASS-user] problem with v.edit tool=merge
Jachym Cepicky
jachym.cepicky at gmail.com
Wed Mar 28 02:55:27 EDT 2007
v.out.ascii of the data would help..
jachym
2007/3/27, Jarek Jasiewicz <jarekj at amu.edu.pl>:
> Martin Landa napisał(a):
> > Hi,
> > could be possible to reproduce this vector data?
> > Martin
> > 2007/3/27, Jaros�aw Jasiewicz <jarekj at amu.edu.pl>:
> >> Hi
> >> I tired:
> >> v.edit map=linie layer=1 type=line tool=merge thresh=0 cats=14,15
> >> and I recived:
> >> GRASS_INFO_MESSAGE(6432,1): [2] of [17] features selected
> >> GRASS_INFO_MESSAGE(6432,2): [0] features merged
> >> GRASS_INFO_MESSAGE(6432,3): v.edit complete.
> >> I also tried with no treshold parameter. Result is the same
> >> but If I use tool=snap all is ok,lines are snapped (but I ecxpect merge,
> >> not only snap)
> >> do I something wrong?
> >> I add it is very simple vector file with few lines, crated to experiment
> >> with that new fascinating tool
> >> Jarek
> >> _______________________________________________
> >> grassuser mailing list
> >> grassuser at grass.itc.it
> >> http://grass.itc.it/mailman/listinfo/grassuser
> thanks for ansver
> but how to reproduce???
> I just simply draw (v.digit) few lines (with categories but without
> table) in new vector.
> Lines look like ---1-- ---2---- ---3---, every line has own cat
> now I try:
> v.edit map=linie layer=1 type=line tool=merge thresh=0 cats=1,2
> GRASS_INFO_MESSAGE(6432,1): [2] of [3] features selected
> and green bar stops at half...
> if I try similar tool:
> v.edit map=linie layer=1 type=line tool=snap thresh=0 cats=1,2
> all goes OK i.e lines are snapped
> I tried it on few files and few machines everywhere it gos the same
> I add, I need that tool. I prepared useful scrpit (for now it works with
> snap option only) which (will be) based
> on that tool. So I need to understand If there is problem with tool and
> I shall look for another solution (or wait) or I do something wrong
> regards
> Jarek
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
