[GRASS-user] bash scripts and NLS
Jarosław Jasiewicz jarekj at amu.edu.pl
Wed Mar 28 03:28:29 EDT 2007
Glynn Clements napisał(a):
>Jarek Jasiewicz wrote:
>>...d.what.vect -1 -t  map=lines|grep category|awk '{print $2}'>>cat.txt...
>>I compiled grass with NLS (national languages suports) and script stop
>>working becouse there is no category (grep) but kategoria (category in
>>polish). In my few scripts it is no problem (or rather I will never use
>>NLS), but what about scripts in grass add-ons and nls?
>If a script parses output which is meant to be human-readable, it
>needs to explicitly set the locale to "C" for that command, e.g.:
>	LC_ALL=C d.what.vect -1 -t ...
thanks, taht is enough
Jarek
