[GRASS-user] Lambert Conformal Conic location
mespana at ugr.es mespana at ugr.es
Wed Mar 28 07:12:13 EDT 2007
Hello dear grassusers,
I'm triying to define a new location for a volume with this data:
Lambert Conformal projection:
	Standard Latitude 1: 60.000000
	Standard Latitude 2: 30.000000
	North/South Pole Row: -61.842026
	North/South Pole Column: 19.503059
	Central Longitude: 85.000000
	Column Increment: 90.000008 km
In 6.3-cvs.
It's a grid over Florida of 34 rows and 40 cols.
I'm selecting this option on the shell-script menu:
D
'Florida location'
projection: lcc
datum: nad27
parameters: 1
Central Parallel:36N
Standart Parallel 1: 60N
Standart Parallel 2: 30N
Central meridian: 85W
False easting: -61.84
False northing: 19.50
After I make the input above  that i don't know if it's correct, i try a
region from 40N 0S 0W 34E, 1 res n-s, 1 res w-e (because I know previously
that the grid is 34x40), but I need to obtain the correct parameters for
the region with the parameters of the projection... I can't calculate the
grid dimensions for the region which adjusts my map... i can't see it.
Anyone can suggest a solution? Maybe I don't understand the region
concept... what are the units which I define the region: meters, pixels,
degrees...? I wonder if I must calculate the boundaries manually,
converting lcc information to x/y.
Thanks in advance.
Miriam
<>   Miriam España Acebal
<>   Ingeniera en Informatica / Computer Science Engineer
<>   Departamento de Fisica Aplicada / Applied Physics Department
<>   G. I. Fisica Atmosferica / Atmospheric Physics Research Group
<>   Universidad de Granada / University of Granada
<>   España / Spain
<>   mespana at ugr.es
