[Fwd: Re: [GRASS-user] some hints for grass 6.3, now on etch !]
Stephan Holl stephan.holl at intevation.de
Thu Mar 29 02:17:38 EDT 2007
Hello Raffaele,
"Raffaele Morelli" <raffaele.morelli at gmail.com>, [20070328 - 13:29:04]
> > Thats the thing , i had no -dev package installed.
> > BUT: My configure script runs through with some hints of finding no
> > gdal but gives at the end
> > GDAL-Support: YES !
> wait, probably you asked for gdal support and configure finds
> gdal-config, which is needed, and probably it worries about missing
> gdal.h header which is provided by libgdal-dev
Let me jump into this too (I have seen georgs setup). The problem is
that configure does not handle gdal-config correct. Evem if you give a
nonexistant path to gdal-config, configure does not bail out with an
error. You need to scroll up to see the error and at the end it gets
summed up that gdal is found.
> I guess its an bug in the configure script.
Yes, definetly.
Best
	Stephan
Stephan Holl <stephan.holl at intevation.de>, http://intevation.de/~stephan
Tel: +49 (0)541-33 50 8 32 | Intevation GmbH | AG Osnabrück - HR B 18998
Geschäftsführer:  Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
