[GRASS-user] Error updating GRASS
António G Rodrigues agrodrigues at ipt.pt
Thu Mar 29 07:08:36 EDT 2007
Hi folks,
I apdated to grass6.2 in my ubuntu system using the repositories in...
deb http://les-ejk.cz/ubuntu edgy multiverse
deb-src http://les-ejk.cz/ubuntu edgy multiverse
The problem is that when opening grass it crashes everytime. The error message is:
GRASS 6.2.1 (Europe):~ > Error in startup script: bad variable name "coords(1)": upvar won't create a scalar variable that looks like an array element
    while executing
"global coords($mon)"
    (procedure "MapCanvas::pointer" line 5)
    invoked from within
"MapCanvas::pointer $mon"
    (procedure "MapCanvas::create" line 226)
    invoked from within
"MapCanvas::create"
    (procedure "Gm::startmon" line 11)
    invoked from within
"Gm::startmon"
    (procedure "Gm::create" line 69)
    invoked from within
"Gm::create"
    (procedure "main" line 30)
    invoked from within
"main $argc $argv"
    (file "/usr/lib/grass/etc/gm/gm.tcl" line 521)
Any clues?
Thanks in advance,
António
