[GRASS-user] Error updating GRASS
Thu Mar 29 18:24:28 EDT 2007
Jachym Cepicky wrote:
> > I apdated to grass6.2 in my ubuntu system using the repositories in...
> > deb http://les-ejk.cz/ubuntu edgy multiverse
> > deb-src http://les-ejk.cz/ubuntu edgy multiverse
> > The problem is that when opening grass it crashes everytime. The error message is:
> > GRASS 6.2.1 (Europe):~ > Error in startup script: bad variable name "coords(1)": upvar won't create a scalar variable that looks like an array element
> >     while executing
> > "global coords($mon)"
> >     (procedure "MapCanvas::pointer" line 5)
> >     invoked from within
> > "MapCanvas::pointer $mon"
> >     (procedure "MapCanvas::create" line 226)
> >     invoked from within
> > "MapCanvas::create"
> >     (procedure "Gm::startmon" line 11)
> >     invoked from within
> > "Gm::startmon"
> >     (procedure "Gm::create" line 69)
> >     invoked from within
> > "Gm::create"
> >     (procedure "main" line 30)
> >     invoked from within
> > "main $argc $argv"
> >     (file "/usr/lib/grass/etc/gm/gm.tcl" line 521)
> > Any clues?
> hi, nobody else reported such problem...
Yes they did:
	http://grass.itc.it/pipermail/grassuser/2007-March/038688.html
	http://grass.itc.it/pipermail/grassuser/2007-March/038689.html
This is fixed in CVS.
