[GRASS-user] GRASS & MODIS L3 data
Ivan Shmakov
ivan at ivanshmakov.homeip.net
Fri Mar 30 23:03:34 EDT 2007
>>>>> Jose Gomez-Dans <jgomezdans at gmail.com> writes:
>> Browsing through the list, I've got an impression that GRASS cannot
>> import MODIS Level 2 data directly. IIUC, the main problem is that
>> the consequent rows of the data sets overlap ``on the Earth'', and
>> it couldn't be fixed by either `i.rectify' or `gdalwarp'. Please
>> correct me if I'm wrong here.
> I use a lot of MODIS data (all levels essentially). Rather than using
> the HEGTools, I have written a small python script that uses GDAL
> (and Markus Neteler's notes on how to reproject MODIS data)
Where I could find these notes?
> to reproject and select the area I want. The ouput is GeoTIFF, which
> can then be easily imported into GRASS.
> If you want to have a look at it, let me know, and I'll send it over.
It would be very interesting to me to see it.
