[GRASS-user] help exporting complex vector files
andrew.haywood at poyry.com andrew.haywood at poyry.com
Wed May 2 20:49:50 EDT 2007
Dear List,
I am looking for some advice on the best way to polygonise large raster
layers into shapefile format
The context for this question is the need to creating a slope-class vector
layer for land-use classification.
The following steps are what I am currently doing
import SRTM data for the area I am interested in and then run r.fillnulls
to fill the gaps
run r.slope.aspect to generate a raster of slope (in percent)
run r.reclass to classify the slope classes into 0-10%, 11-20%, 21-30%
.... 81-90%, 90-100% 100+%
then run a r.neighbour with type=mode on a 3 by 3 window to smooth some of
the salt and pepper effect away.
then run r.to vect with the area flag to create a vector representation of
slope
This usually creates a vector with tens of thousands of polygons
Then I run a v.out.ogr to create a shapefile
The last step is when I run into problems with 50 000 or more polygons.
The shapefile tends to be corrupted with empty values in the dbf for slope
and doesn't reflect the vector file in the grass format.
The current work around is export the slope raster file as a tiff file.
Import into arcgis then convert to shapefile. This approach im not happy
with!! So any solutions would be greatly appreciated.
Kind regards
Andrew
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070503/fa98b360/attachment.html
