[GRASS-user] which version of GRASS should I choose to install in a Suse 10.2 i386 version ?
Stephan Holl stephan.holl at intevation.de
Fri May 11 05:43:58 EDT 2007
Hello Raymond,
Raymond Fu <raymond_fu at yahoo.com>, [20070511-17:28:04]:
> Thanks.  However when I run the installation, it returns errors as
> belows.  How can I proceed the installation?  Did I miss certain
> settings?
> OSS at linux-s3qw:~/Desktop/Work/OpenSource/GRASS/SuseV10.2> rpm -Uhv
> geos-2.2.3-1suse10.2.i586.rpm error: can't create transaction lock
> on /var/lib/rpm/__db.000
You need to be root to install RPM-packages. This should cure the above
behaviour.
Best
	Stephan
Stephan Holl <stephan.holl at intevation.de>, http://intevation.de/~stephan
Tel: +49 (0)541-33 50 8 32 | Intevation GmbH | AG Osnabrück - HR B 18998
Geschäftsführer:  Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
