[GRASS-user] r.sim.water - error
Markus Neteler neteler at itc.it
Mon May 14 14:54:51 EDT 2007
On Mon, May 14, 2007 at 01:32:07PM -0500, M S wrote:
>    The 6.3 manual is much more clear about this than the 6.2 manual.  The
>    infil map is the rate at which the ground absorbs water once the soil is
>    saturated (surface water already flowing), not when it is dry.   Also the
>    mm/hr units was a big help.  the 6.3 manual says that x,y,z can be in
>    feet, as well as the dx,dy (ft/ft), but the rain and infil in mm/hr.
>    Thanks!  Looks like I might have some results by tomorrow.
>    Mark
Good - please keep us posted! And don't hesitate to hack the
HTML documentation directly if things should be clarified -
we can then merge it.
Markus
