[GRASS-user] which version of GRASS should I choose to install in a Suse 10.2 i386 version ?
Otto Dassau otto.dassau at gmx.de
Wed May 16 08:10:13 EDT 2007
Hi Raymond,
you should find the procedure to add a package repository for Suse 10.2 here:
http://en.opensuse.org/Add_Package_Repositories_to_YaST
regards,
 Otto
On Wed, 16 May 2007 18:32:37 +0800 (CST)
Raymond Fu <raymond_fu at yahoo.com> wrote:
> thanks.  I can download all of the dependent file except libmysqlclient.so.15.
 I am using YAST to download (software-> add-on product).  But it need me to
tell the server.   How should I input?  or am I doing in the right way?
> Thank a lot.
> Raymond
> Stephan Holl <stephan.holl at intevation.de> wrote: Hello Raymond,
> Raymond Fu , [20070514 - 18:07:52]
> > hi Markus,Stephan,
> > Thanks, it can proceed installation of first few files as stated in
> > readme file.  However when  grass-6.2.1-1suse10.2.i586.rpm is
> > installed, it returns below error?   How can I proceed the
> > installation?   Do I need to install certain extra file first?
> > linux-s3qw:~/Desktop/GRASS# rpm -Uhv grass-6.2.1-1suse10.2.i586.rpm
> > error: Failed dependencies:
> >         unixODBC is needed by grass-6.2.1-1suse10.2.i586
> >         fftw3 is needed by grass-6.2.1-1suse10.2.i586
> >         libfftw3.so.3 is needed by grass-6.2.1-1suse10.2.i586
> >         libmysqlclient.so.15 is needed by grass-6.2.1-1suse10.2.i586
> >         libmysqlclient.so.15(libmysqlclient_15) is needed by
> > grass-6.2.1-1suse10.2.i586 libodbc.so.1 is needed by
> These files need to be installes using your suse-installer called yast.
> After that, you need to do:
> This should work then.
> Best
>  Stephan
