[GRASS-user] No access to most of my point vectors
Michael Barton michael.barton at asu.edu
Fri May 18 12:15:57 EDT 2007
Agustin,
Silly question perhaps, but have you run v.build?
Michael
On 5/18/07 8:47 AM, "Agustin Diez Castillo" <Agustin.Diez at uv.es> wrote:
> I've lost access to most of my vector files in a mapset (adiez2 is the mapset
> where I'm working even if it shows up like @ at the GUI) Is there anyway to
> recover then other than reimporting the dbf.
> When I try to deploy
> d.vect map=ACas260207b at adiez2 color=0:0:0 lcolor=0:0:0 fcolor=170:170:170
> display=shape type=point icon=basic/circle size=5 layer=1 lsize=8 xref=left
> yref=center llayer=1
> Size of 'coor' file differs from value saved in topo file.
> Please rebuild topology for vector 'ACas260207b at adiez2'
> Cannot open topo file for vector map <ACas260207_PS_EP at adiez2>
> When I try
> v.build map=ACas260207b at adiez2 option=build --overwrite
> coor files of vector 'ACas260207b at adiez2' is larger than it should be
> (15145471 bytes excess).
> Building topology ...
> Registering lines:
> But the dbf is there
> ^C_^G^Z<E5>^@^@^@!^C5^A^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@str_1^@^@^@^@^@
> ^@C^@^@^@^@*^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@int_1^@^@^@^@^@^@N^@^@^@^@^K^@^@^@^@
> ^@^@^@^@^@^@int_2^@^@^@^@^@^@N^@^@^@^@^K^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@dbl_1^@^
> @^@^@^@^@N^@^@^@^@^T^F^@^@^@^@^@^@^@^@^@^@^@^@^@^@str_2^@^@^@^@^@^@C^@^@^@^@^G
> ^@^@^@^@^@^@^@^@^@^@str_3^@^@^@^@^@^@C^@^@^@^@^K^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@
> str_4^@^@^@^@^@^@C^@^@^@^@^V^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@str_5^@^@^@^@^@^@C^@
> ^@^@^@^V^@
> ^@^@^@^@^@^@^@^@^@^@^@^@^@^@int_3^@^@^@^@^@^@N^@^@^@^@^K^@^@^@^@^@^@^@^@^@^@^@
> ^@^@^@^@int_4^@^@^@^@^@^@N^@^@^@^@^K^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@int_5^@^@^@^
> @^@^@N^@^@
> ^@^@^K^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@int_6^@^@^@^@^@^@N^@^@^@^@^K^@^@^@^@^@^@^@
> ^@^@^@^@^@^@^@^@int_7^@^@^@^@^@^@N^@^@^@^@^K^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@str_
> 6^@^@^@^@
> ^@^@C^@^@^@^@^C^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@int_8^@^@^@^@^@^@N^@^@^@^@^K^@^@^
> @^@^@^@^@^@^@^@^@^@^@^@^@int_9^@^@^@^@^@^@N^@^@^@^@^K^@^@^@^@^@^@^@^@^@^@^@^@^
> @^@^@int_1
> 0^@^@^@^@^@N^@^@^@^@^K^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@int_11^@^@^@^@^@N^@^@^@^@^
> K^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@int_12^@^@^@^@^@N^@^@^@^@^K^@^@^@^@^@^@^@^@^@^@
> int_13^@^@^@^@^@N^@^@^@^@^K^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@int_14^@^@^@^@^@N^@^@
> ^@^@^K^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@int_15^@^@^@^@^@N^@^@^@^@^K^@^@^@^@^@^@^@^
> ^@^@^@str_7^@^@^@^@^@^@C^@^@^@^@^E^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@int_16^@^@^@^@
> ^@N^@^@^@^@^K^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^M Encantada
>      730324    4300460          298.000000AC-enc Alc/Com    Lorxa
>                          ***********          1          1
> 0***********   ****
> ******          999999 TOSSAL DE LA ROCA (VALL D'ALCAL<C3><8B>
> 735500    42
> 97100********************C70    Alc/Com    ALCALA                VALL
> D'ALCAL<C3><8B>
>      10070 COVA DE L'ALIGA (VALL D'ALCAL<C3><8B>                740000
> 4298900******
> **************C69    Marina AltaALCALA                VALL D'ALCAL<C3><8B>
> **************************************************************           10069
> PENYA DEL COMPTADOR (ALCOI                     720900
> 4282500********************C68
>     Alc/Com    Serpis                ALCOI
> ***************************************           10068 COVA DE PISCINA
> (BOCAIRENT                     708000    4294100********************C67    V.
> Albaida Albaida
>               BOCAIRENT
> ****************           10067 ABRIC DEL BARRANC DE LES CALDERES (PLANES
>   732900    4296700********************C66    Alc/Com    Almudaina
> Planes
>     10066 ABRIC DE LA FALGUERA (ALCOI                    720700
> 4282900********************C65    Alc/Com    Polop                 ALCOI
> **********           10065 COVA DEL GARR
> OFER (ONTINYENT                   708000    4296900********************C64
> V. Albaida Albaida               ONTINYENT
> **********           10064 COVA DE LA GERRA (BOCAIRENT
>            708500    4295400********************C63    V. Albaida Albaida
>          BOCAIRENT
> **********           10063 COVETA EMPARET<C3><8B> (BOCAIRENT
>   709400
>     4293200********************C62    V. Albaida Albaida
> BOCAIRENT
>      10062 COVA DE LA SARSA (BOCAIRENT                    709900
> 4293400************
> __________________________________________________________
> Dr. Agustín Diez Castillo
> Departament de Prehistòria i Arqueologia
> Fundació General Universitat de València     Phone:   +34 963 98 38 93
> Avda. Blasco Ibañez, 28     Fax:       +34 963 98 38 87
> València 46010
> http://www.uv.es/sidgeipa
> Member of the European Network of Excellence EPOCH
> http://www.epoch.eu/
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070518/913415fd/attachment.html
