[GRASS-user] No access to most of my point vectors
Agustin Diez Castillo Agustin.Diez at uv.es
Sat May 19 06:35:17 EDT 2007
True, bu the points are going with the wind, event if they are in the
dbf.
str_1,C,42,int_1,N,11,0,int_2,N,11,0,dbl_1,N,20,6,str_2,C,7,str_3,C,
11,str_4,C,22,str_5,C,22,int_3,N,11,0,int_4,N,11,0,int_5,N,
11,0,int_6,N,11,0,int_7,N,11,0,str_6,C,3,int_8,N,11,0,int_9,N,
11,0,int_10,N,11,0,int_11,N,11,0,int_12,N,11,0,int_13,N,11,0,int_14,N,
11,0,int_15,N,11,0,str_7,C,5,int_16,N,11,0
Cova del Moro ? MAL,723100,4299800,590,C51,Alc/Com,Muro (El
Comtat),Muro,0,0,0,0,0,0,0,0,0,1,0,0,0,0,,10051
Cova de lÕOr,728700,4303000,650,C50,Alc/
Com,Travadell,BeniarrŽs,0,0,0,0,0,1,1,0,1,1,0,0,0,0,,10050
Cova dÕEn Pardo,734700,4299800,640,C20,Alc/Com,Planes (El
Comtat),Planes,0,1,0,0,1,1,1,1,1,1,0,1,0,0,,10020
Cova de lÕAlgeps,738900,4294600,790,C19,Alc/Com,Tollos (El
Comtat),Tollos,0,0,0,0,0,0,0,0,0,1,0,0,0,0,,10019
Cova del Moro,715400,4294600,900,C17,Alc/Com,Agres,Agres,
0,0,0,0,0,0,1,0,0,1,0,1,0,0,,10017
Cova de Bolumini,712700,4293100,103,C16,V. Albaida,Albaida,Alfafara,
0,0,0,0,0,0,0,0,0,1,1,1,0,0,,10016
Coveta de la Paella,721200,4292200,700,C14,Alc/Com,Cocentaina (El
Comtat),Cocentaina,0,0,0,0,0,0,0,0,0,1,0,0,0,0,,10014
Cova del Pou,721200,4292200,875,C13,Alc/Com,Cocentaina (El
Comtat),Cocentaina,0,0,0,0,0,0,0,0,0,1,1,0,0,0,,10013
Cova del Balconet/Cova Fosca de lÕAlberri,
721100,4291900,760,C11,Alc/Com,Cocentaina (El Comtat),Cocentaina,
0,0,0,0,0,0,0,0,0,1,1,1,0,0,,10011
What I did
v.build
coor files of vector 'ACas260207_NIIb at adiez2' is shorter than it
should be (1309079730 bytes missing).
Building topology ...
Registering lines:
0 primitives registered
Building areas:
0 areas built
0 isles built
Attaching islands:
Attaching centroids: Topology was built.
Number of nodes     :   0
Number of primitives:   0
Number of points    :   0
Number of lines     :   0
Number of boundaries:   0
Number of centroids :   0
Number of areas     :   0
Number of isles     :   0
and then v.digit that reported that the map was back to its correct size
On May 18, 2007, at 8:22 PM, Maciej Sieczka wrote:
> Agustin Diez Castillo wrote:
>> Michael,
>> Yes I did
>> v.build map=ACas260207b at adiez2 option=build
>> and not results, well yes those:
>> coor files of vector 'ACas260207b at adiez2' is larger than it should be
>> (15145471 bytes excess).
> This problem can be solved if you just open the vector in v.digit and
> quit. That will fix the vector.
> Maciek
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070519/e4699d1d/attachment.html
