[GRASS-user] problem in v.in.ogr
temiz temiz at deprem.gov.tr
Mon May 21 13:51:43 EDT 2007
hello
when I use
v.in.ogr dsn="PG:host=localhost  dbname=bzk2  user=postgres"
layer=shey8  output=expand1  type=boundary,centroid
grass says: ERROR: Layer 'shey8' not available
in psql side:
the structure looks:
bzk2=> \d shey8 ;
               Table "public.shey8"
      Column       |       Type        | Modifiers
 ogc_fid           | integer           |
 wkb_geometry      | geometry          |
 cat                  | integer           |
 tip                   | character varying |
 cat_                | integer           |
 aktivite           | character varying |
 kutle               | character varying |
 dem_stat_n        | double precision  |
 dem_stat_min      | double precision  |
 dem_stat_max      | double precision  |
 dem_stat_range    | double precision  |
 dem_stat_mean     | double precision  |
 dem_stat_stddev   | double precision  |
 dem_stat_variance | double precision  |
 dem_stat_cf_var   | double precision  |
 dem_stat_sum      | double precision  |
 minx              | double precision  |
 miny              | double precision  |
 catmin            | integer           |
 zmin              | integer           |
 maxx              | double precision  |
 maxy              | double precision  |
 catmax            | integer           |
 zmax              | integer           |
what might te problem be ?
regards
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
