[GRASS-user] Is d.vect connected to other database than db.*?
Maximilian Krambach Maximilian.Krambach at gmx.de
Thu May 24 01:28:59 EDT 2007
I got two computers (both ubuntu edgy, grass 6.2.1) working on the same grass project (not simultaneously, one at home, one at work). However, the users are named different, so the  $GISDBASE is as following:
/home/user1/database/location/mapset
/home/user2/subdirectory/database/location/mapset
Now user2 has a problem with d.vect. Whenever querying something from a vector, there goes the error "DBMI-DBF driver error: cannot open database: /home/user1(!)/database/location/mapset". db.connect is set correctly to '/home/user2/...' Is there another connection of databases to be done?
Der GMX SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
Ideal für Modem und ISDN: http://www.gmx.net/de/go/smartsurfer
