[GRASS-user] gdal - r.in.onearth
Sören Gebbert soerengebbert at gmx.de
Thu May 24 20:29:09 EDT 2007
i have fixed this issue. A new grass6.3-cvs compatible version
available from the grass add-on page.
The reason for this behaviour was the changes of the -bg options in g.region.
Now it should work with grass6.3.
Best regards
Soeren
Tomas Lanczos schrieb:
> I tried to download some landsat7 pictures by r.in.onearth, but I got
> the following errormessage (see the end of the message).
> Should I recompile the gdal (if yes, whitch option used) or any other
> workarounds proposed?
> Thank You
> Tomas
> p.s.: using Grass 6.3.CVS and 6.2.1 on Ubuntu Feisty Fawn
> Downloaded file is not a GeoTiff file, but will try to import
> ************** CHECK DATA *****************
> ERROR 4:
> `/home/tomas/grassdata/Slovakia/PERMANENT/.tmp/thor/20010.0/Image_global_mosaic_base_visual__'
> not recognised as a supported file format.
> GDALOpen failed - 4
> ERROR 4:
> GDALOpen failed - 4
> !-------------------BREAK---------------------!
> Downloaded file is not supported by gdal, or cannot be imported
> File of Type:  "        XML
> Message from Server http://wms.jpl.nasa.gov/wms.cgi
> !------------BEGIN-ERROR-MESSGAE--------------!
> <?xml version='1.0' encoding="UTF-8" standalone="no" ?>
> <!DOCTYPE ServiceExceptionReport SYSTEM
> "http://www.digitalearth.gov/wmt/xml/exception_1_1_0.dtd ">
> <ServiceExceptionReport version="1.1.0">
>   <ServiceException>
>     Bounding box has an invalid area
>   </ServiceException>
> </ServiceExceptionReport>
> !-------------END-ERROR-MESSGAE---------------!
> Finished
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
