[GRASS-user] Some questions
Thu May 31 04:57:52 EDT 2007
Martin Besta wrote:
> Can I edit the column header (name and type) of attribute table?
I think you can edit DBF column headers in OpenOffice.
> Is it possible to remove some columns from the table with Grass?
GRASS 6.3cvs has:
v.db.addcol
v.db.connect
v.db.droptable
v.db.renamecol
v.db.update
v.db.addtable
v.db.dropcol
v.db.reconnect.all
v.db.select
(these are mostly/all? just shell scripts)
v.db.renamecol and v.db.dropcol should do the trick.
you can do any/most raw SQL commands with db.execute.
Hamish
