[GRASS-user] creating shape files from text files
Fri Nov 23 17:55:23 EST 2007
nishith datta wrote:
> I wish to create a ellipsoid around a point , the semi major and semi minor
> axis dist are known, which means the coordinates of the bounding rectangle
> can be calculated easily.
> Can I create a csv or a text file to generate a shape file from it using
> some program like gen2shp.
> What should be the format of the text file ?
> is there any other way to do it in grass or quantum gis?
calculate the coordinates and use 'v.in.ascii format=standard'
see the v.in.ascii help page.
export to a shapefile with v.out.ogr
Hamish
      ____________________________________________________________________________________
Be a better sports nut!  Let your teams follow you
with Yahoo Mobile. Try it now.  http://mobile.yahoo.com/sports;_ylt=At9_qDKvtAbMuh1G1SQtBI7ntAcJ
