[GRASS-user] Correction of terrain effects for MODIS data?
Fri Nov 30 18:10:55 EST 2007
Nikos Alexandris wrote:
> I tried to follow the example for correction of terrain effects in a MODIS
> surface reflectance NIR band
> (...as far as I know, MODIS surface reflectance imagery is only corrected
> for atmospheric effects).
> I don't get the desired results... The output is too bright from what one
> would expect it to be.
> Any recommendations?
I've never used it for MODIS, but you could try i.landsat.rgb to see if that
helps. (it wants three 0-255 bands, it doesn't care about it being LANDSAT or
not)
Hamish
      ____________________________________________________________________________________
Never miss a thing.  Make Yahoo your home page.
http://www.yahoo.com/r/hs
