[GRASS-user] little question about configure and PostgreSQL
Brad Douglas rez at touchofmadness.com
Fri Oct 5 15:15:39 EDT 2007
On Fri, 2007-10-05 at 09:33 +0200, Jarosław Jasiewicz wrote:
> Glynn Clements napisał(a):
> > Jarek Jasiewicz wrote:
> >> have "--with-postgres" been removed as default from configure script??
> > Yes, it's no longer enabled by default in the latest CVS version.
> Thanks!
> IMHO It's good idea (in spite of postgres is my main database in grass)
> But I have little sugestion (for all). If some changes like this will be
> made (i.e which require new or addational behavior during compilation
> cvs please inform about it on "grass-user"
I believed I cc:'d grass-user on the thread, but it was generally
discussed last.
Never take default options for granted with any software; especially
software in a development cycle.  I always setup a shell script that
runs 'configure' with the options I want spelled out so there is no
confusion.
If you require stability and predictability, you shouldn't be using
6.3.x. ;-)
73, de Brad KB8UYR/6 <rez touchofmadness com>
