[GRASS-user] sql and postgis
Moritz Lennert mlennert at club.worldonline.be
Tue Oct 30 14:32:17 EDT 2007
On 30/10/07 19:14, Gustavo Martinez wrote:
> El Tuesday 30 October 2007 15:00:30 escribió:
>> On 30/10/07 18:28, Gustavo Martinez wrote:
>>> El Monday 29 October 2007 12:53:20 escribió:
>>>>> Moritz,
>>>>> the result of  v.db.connect monitoreo -p is:
>>>>> Vector map <monitoreo> is connected by:
>>>>> layer <1> table <monitoreo> in database <PG:host=localhost
>>>>> dbname=pesca-new user=postgres> through driver <ogr> with key <>
>>>> There's the problem: 'with key <>'. GRASS does not know how to link the
>>>> geographical data (the map) to the attribute data. This is where the
>>>> SELECT FROM comes from, i.e., nothing to select.
>>>> As I said, I'm not sure that a map linked into GRASS with v.external can
>>>> be used for database queries. Also don't know what the ogr driver
>>>> supports.
>>>> You could try to relink the map directly to the postgresql table with
>>>> something like
>>>> v.db.connect -o map=monitoreo driver=pg database="host=localhost
>>>> dbname=pesca-new" table=monitoreo key=XXX
>>>> where XXX is the column that contains the identifiers of the
>>>> geographical objects in your map.
>>>> Moritz
>>> I've tried the following command:
>>> v.db.connect -o map=monitoreo driver=pg database=pesca-new
>>> table=monitoreo key=idmonitoreo layer=1
>>>  and it gave me the following:
>>> pg driver: column 'fecha', type 1184  is not supported
>>> pg driver: column 'fch_local', type 1184  is not supported
>>> pg driver: PostGIS column 'geom', type 'geometry'  will not be converted
>>> The table <monitoreo> is now part of vector map <monitoreo> and may be
>>> deleted or overwritten by GRASS modules
>>> However, if I tgry again
>>> v.db.connect monitoreo -p the key field is still empty.
>> What is the output of v.db.connect -p ?
>> I'm not sure I can help you any further, but my guess would be that
>> there is a difference in the handling of maps linked via v.external
>> compared to maps which are imported into GRASS...
>> Moritz
So v.db.connect -o actually did not work (driver is still ogr).
I would recommend that you import the map into GRASS with v.in.ogr, do
what you have to there and then export it again to PostGIS with v.out.ogr.
Moritz
