[GRASS-user] Re: Fwd: r.le Problem
Martin_Besta martin.besta at googlemail.com
Sun Sep 2 13:13:49 EDT 2007
Hi Hamish,
coudl you specify, what does the problem 2 mean? The map, used for
r.li.shannon, in r.le.patch does work.
Ad problem 1
I dont understand, why the file name repeats "/home/martin/.r.li/history/"
twice. In path to file is this set only once
Paolo,
please, could you send me some configuration file for r.li.shannon, that
does work? (sampling areas from the overlayed vector layer)#
Thanks
Martin
HamishB wrote:
>> Martin Besta ha scritto:
>> > I have tried r.li <http://r.li> for Shannon index calculation...BUT...
>> > I wanted to set my rectangles from vector layer as a sampling areas,
>> > however, if I try in r.li.shannon to choose configutration file (made
>> > beforehand) I recieve this error message:
>> > Cannot make stat of
>> > /home/martin/.r.li/history//home/martin/.r.li/history/natura_clean
>> > configuration file
>> > Illegal filename. Character <#> not allowed.
>> > Can't open header file for [(#å·P#å·#A¿ in (null)]
> problem 1:
> the filename above repeats the "/home/martin/.r.li/history/" part twice.
> problem 2:
> some variable (a map name) is being used uninitialized. presumably this
> is because the config file couldn't open but the module marched on anyway.
> It should include some more checks and G_fatal_error()s apparently.
> Hamish
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
View this message in context: http://www.nabble.com/Re%3A-Fwd%3A-r.le-Problem-tf4353021.html#a12451220
Sent from the Grass - Users mailing list archive at Nabble.com.
