[GRASS-user] Re: grass.bat script for Cygwin GRASS 6.2.2-1
Markus Neteler neteler at itc.it
Wed Sep 5 04:18:02 EDT 2007
Glynn Clements wrote:
> Markus Neteler wrote:
>> >> broken, apprently due to tools/build_html_index.sh error:
>> >>>    index.html
>> >>>    full_index.html
>> >>>    grassdocs.css
>> Now we need someone who builds again and watches out for errors
>> originating from tools/build_html_index.sh + r.support Makefiles.
> There was an error in the "locale" directory (caused by having a
> native "msgfmt" in the path), so build_html_index.sh didn't get run.
> The message catalogues all seem to be there, so I think that I re-run
> "make -C locale" manually and failed to notice the build_html_index.sh
> issue.
> I doubt that those files are likely to be platform-dependent, so they
> could just be copied over from e.g. a Linux build of 6.2.2.
OK, done.
http://grass.itc.it/grass62/binary/mswindows/
-> grass-6.2.2-2.cygwin.tar.bz2 (setup.ini also updated)
Do you have any idea about the not stripped .exe extension in the
r.support subdirs?
Markus
View this message in context: http://www.nabble.com/Native-wingrass-6.3.cvs-tf4318056.html#a12493737
Sent from the Grass - Users mailing list archive at Nabble.com.
