[GRASS-user] extrude vector points
Martin Landa landa.martin at gmail.com
Fri Sep 7 06:43:24 EDT 2007
now in CVS possible also using v.transform.
Martin
E.g.
# create table containing transformation parameters
echo "create table archsites_trans (cat int, zs double)" | db.execute
# insert transformation parameters for category 1
echo "insert into archsites_trans values (1, 1000)" | db.execute
# insert transformation parameters for category 2
echo "insert into archsites_trans values (2, 2000)" | db.execute
# connect table contaning transformation parameters
v.db.connect archsites layer=1 table=archsites_trans -o
# perform transformation
v.transform in=archsites out=archsites_t col="zshift:zs"
# reconnect original table
v.db.connect archsites layer=1 table=archsites -o
# drop table contaning transformation parameters
echo "drop table archsites_trans" | db.execute
2007/8/23, Luigi Ponti <lponti at infinito.it>:
> Dear list,
> Is there a way to "extrude" 2D vector points to 3D points based on
> attribute column values, similar to what I have read v.extrude can do
> with lines? I have tried to use v.extrude with points but an empty 3D
> vector was created.
> Thanks and regards,
> Luigi
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
