[GRASS-user] problems with v.report
Maciej Sieczka tutey at o2.pl
Sun Sep 9 09:56:21 EDT 2007
Maciej Sieczka wrote:
> dziadgba dziadgba wrote:
>> hy everybody, I am working on a project involving geografical data.
>> I used grass61 until the end of june, now I reinstalled my system
>> and but grass62.
>> The problem is that when I try to use v.report on a layer containing
>> points.
>> v.report map=roadmapCleanedAndSplit layer=1 option=coor
>> strangely the list I get includes only the x coordinate, y coodinate
>> is missing.
>> output: cat|type|name|active|line|segment|x|y
>> 16021||||||681109.126691232 16022||||||678959.20221614
> I confirm the bug in GRASS 6.3 CVS. Please report it to the tracker.
> Maybe someone will take care of it.
I did :). Submitted to 6.3 CVS. Also attached to this email - please test.
I'd like to backport it to 6.2 if nobody minds.
Maciek
#!/bin/sh
# MODULE:	v.report
# AUTHOR(S):	Markus Neteler
# PURPOSE:	Reports geometry statistics for vector maps
# COPYRIGHT:	(C) 2005, 2007 by MN and the GRASS Development Team
#		This program is free software under the GNU General Public
#		License (>=v2). Read the file COPYING that comes with GRASS
#		for details.
#%Module
#%  description: Reports geometry statistics for vectors.
#%  keywords: vector, report, statistics
#%End
#%Flag
#% key: r
#% description: Reverse sort the result
#%End
#%Flag
#% key: s
#% description: Sort the result
#%End
#%option
#% key: map
#% type: string
#% gisprompt: old,vector,vector
#% description: Name of input vector map
#% required: yes
#%end
#%option
#% key: layer
#% type: integer
#% answer: 1
#% description: Layer number
#% required: no
#%end
#%option
#% key: option
#% type: string
#% description: Value to calculate
#% options: area,length,coor
#% required: yes
#%end
#%option
#% key: units
#% type: string
#% description: mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares)
#% options: mi,miles,f,feet,me,meters,k,kilometers,a,acres,h,hectares,p,percent
#% required: no
#%end
if  [ -z "$GISBASE" ] ; then
 echo "You must be in GRASS GIS to run this program." >&2
 exit 1
fi
if [ "$1" != "@ARGS_PARSED@" ] ; then
  exec g.parser "$0" "$@"
fi
### setup enviro vars ###
eval `g.gisenv`
: ${GISBASE?} ${GISDBASE?} ${LOCATION_NAME?} ${MAPSET?}
LOCATION=$GISDBASE/$LOCATION_NAME/$MAPSET
### trap <ctrl>-<c> so that we can clean up tmp and exit
trap 'rm -f "$TMP1" "$TMP2" "$TMP3" "$TMP4"; exit 1' 2 3 15
# setting environment, so that sort works properly in all languages
LC_ALL=C         # according to 'man sort'
export LC_ALL
LC_NUMERIC=C
export LC_NUMERIC
if [ $GIS_FLAG_R -eq 1 -a $GIS_FLAG_S -eq 1 ] ; then
	g.message -e "Either -r or -s flag"
	exit 1
fi
### secure temporary files:
TMP1="`g.tempfile pid=$$`"
TMP2="`g.tempfile pid=$$`"
TMP3="`g.tempfile pid=$$`"
TMP4="`g.tempfile pid=$$`"
MAP=$GIS_OPT_MAP
OPTION=$GIS_OPT_OPTION
LAYER=$GIS_OPT_LAYER
# does the input vector exist?
eval `g.findfile element=vector file=$GIS_OPT_MAP`
if [ ! "$file" ] ; then
   g.message -e "Vector map '$GIS_OPT_MAP' not found in mapset search path"
   exit 1
fi
#test if the input vector has a table attached in the given layer
v.info -c map=$MAP layer=$LAYER >/dev/null 2>&1
if [ $? -eq 0 ] ; then
 TABLEEXISTS=1
else
 TABLEEXISTS=0
fi
#fetch column names
if [ $TABLEEXISTS -eq 1 ] ; then
 COLNAMES="`v.info -c map=$MAP layer=$LAYER | grep -v '^Displaying column type' | cut -d '|' -f2 | tr '\n' '|'`"
else
 COLNAMES="cat|"
fi
#special treatment for opt=coor parameter:
if [ "$GIS_OPT_OPTION" = "coor" ] ; then
  COLUMS="dummy1,dummy2,dummy3"
  EXTRACOLNAMES="x|y|z"
else
  COLUMS="dummy1"
  EXTRACOLNAMES="$OPTION"
fi
#check for optional units parameter:
if  [ ! -z $GIS_OPT_UNITS ] ; then
    UNITSPARAM="units=$GIS_OPT_UNITS"
    # reset to meters since percent are unsupported in v.to.db
    if [ "$GIS_OPT_UNITS" = "p" -o "$GIS_OPT_UNITS" = "percent" ] ; then
       UNITSPARAM="units=meters"
    fi
fi
## NOTE: we suppress -1 cat and 0 cat
#fetch the attributes sorted by cat:
 v.db.select -c map=$MAP layer=$LAYER | sort -n -t'|' -k 1 | grep -v '^0' > "$TMP1"
else
 v.category input=$MAP layer=$LAYER option=print | sort -n -t'|' -k 1 | grep -v '^0' > "$TMP1"
fi
if [ `wc -l "$TMP1" | awk '{print $1}'` -eq 0 ] ; then
   #fetch the areas/line lengths sorted by cat:
   v.to.db -p map=$MAP opt=$OPTION col=$COLUMS $UNITSPARAM \
	   layer=$LAYER 2> /dev/null | grep -v '^cat' | grep -v '^-1' | grep -v '^0'\
	   | sort -n -t'|' -k 1 > "$TMP2"
else
	   | sort -n -t'|' -k 1 | cut -d'|' -f2-4 > "$TMP2"
fi
#make and print the table:
NUMCOLS=`echo "$COLNAMES$EXTRACOLNAMES" | tr -s '|' ' ' | wc -w | awk '{print $1}'`
# save pre-table
paste -d'|' "$TMP1" "$TMP2" > "$TMP3"
       # calculate total area value
       AREATOT=`cat "$TMP3" | cut -d'|' -f$NUMCOLS | awk  -F '|' 'BEGIN {sum = 0.0}
       NR == 1{}
               {sum += $1}
       END{
       print sum
       # calculate area percentages
       cat "$TMP3" | cut -d'|' -f$NUMCOLS | awk '{printf "%f\n", $1/'$AREATOT' * 100.}'  > "$TMP4"
       paste -d'|' "$TMP1" "$TMP4" > "$TMP3"
    fi
fi
if [ $GIS_FLAG_S -eq 1 ] ; then
	# sort
	cat "$TMP3" | sort -n -t'|' -k${NUMCOLS}
else
	if [ $GIS_FLAG_R -eq 1 ] ; then
	# reverse sort
	cat "$TMP3" | sort -n -r -t'|' -k${NUMCOLS}
        else
	   # no sort (order by cat)
	   cat "$TMP3"
        fi
fi
#cleanup:
rm -f "$TMP1"
rm -f "$TMP2"
rm -f "$TMP3"
rm -f "$TMP4"
exit 0
