[GRASS-user] solving libgdal.so.1 problem without root permissions
Maris Nartiss maris.gis at gmail.com
Tue Sep 11 02:37:24 EDT 2007
this error means that Your GRASS installation can not access GDAL
library. First You have to check is GDAL/OGR library installed on that
system. Most likely it is not. There are only two solutions then:
1) Ask system administrator to install GDAL/OGR and GRASS;
2) Install GDAL/OGR and GRASS from source in Your home directory and
set up manually all paths (LD_LIBRARY_PATH, PATH).
Maris.
2007/9/11, dziadgba dziadgba <dziadgba at googlemail.com>:
> hy everybody,
> I would like to do some longer calculation on a computer for which I have an
> acccount but I do not have the root password.
> after installing grass6.2 I got the know error
> g.remove: error while loading shared libraries. libgdal.so.1: cannot open
> shared object file.
> I saw the answers to previous posts with:
> /etc/ld.so.conf, "ldconfig" as root.
> but as I can not access as root how could I overcome the problem?
> thx
> dziadgba
