[GRASS-user] importing GMT grids
Carlos "Guâno" Grohmann carlos.grohmann at gmail.com
Mon Sep 17 17:12:17 EDT 2007
any good advice on importing GMT grids? r.in.bin keeps complaining
about the file size, no matter what byte size I choose, and setting it
to get the header from the grid, makes it error on "east must be
larger than west". Exporting the grid to xyz (grd2xyz) and then
importing with r.in.xyz seems to work, but the resulting image is full
of artifacts (see attach). I tried to change the grid registration in
GMT (grdedit), and the boundaries too (in surface), giving it a
half-pixel difference, but all came in the same way.
If anyone wants to try, this is the xyz file:
http://www.igc.usp.br/pessoais/guano/temp/3arcsec.csv
and these are the commands I used:
nearneighbor 3arcsec.csv -R337575/351435/3855915/3872175 -I30/30 -S200
-V -Goutnear.grd
grdedit outnear.grd -T
grdinfo outnear.grd
grd2xyz outnear.grd --D_FORMAT=%f >near.xyz
and
surface 3arcsec.csv -R337575/351435/3855915/3872175 -I30/30 -T0.35 -V -Gout.grd
grdedit out.grd -T
grdinfo out.grd
grd2xyz out.grd --D_FORMAT=%f >spline.xyz
the commands above have the "half pixel displacement" I mentioned, for
this region:
projection: 1 (UTM)
zone:       11
datum:      wgs84
ellipsoid:  wgs84
north:      3872190
south:      3855900
west:       337560
east:       351450
nsres:      30
ewres:      30
rows:       543
cols:       463
cells:      251409
thanks
Carlos
              Carlos Henrique Grohmann - Guano
  Visiting Researcher at Kingston University London - UK
  Geologist M.Sc  - Doctorate Student at IGc-USP - Brazil
Linux User #89721  - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
Can't stop the signal.
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20070917/8ab827af/import.jpg
