[GRASS-user] NVIZ - tiled legend in maximum resolution ppm
Jarek Jasiewicz jarekj at amu.edu.pl
Thu Sep 20 08:01:53 EDT 2007
Hamish wrote:
> Jarek Jasiewicz wrote:
>> In Nviz when I need to save visualisation as maximum rosolution ppm, and
>> I have legend added, the legend (but not the north arrow!) is tiled over
>> the image regulary  12 times.
>> There are no such problems in saving as normal ppm or tif.
> is the rest of the image ok, is it just the legend which is repeated?
> see bug #3041
>   https://intevation.de/rt/webrt?serial_num=3041
> does it work ok for you if you use GRASS 6.2.2?
I tried by I cannot place a scale in grass 6.2.2 (in fact I almost have
never used that version of grass, so cannot say why) so  I cannot answer
this
> does it work ok if you don't use a legend?
All render ok exept legend, anyway legend is added or not
Jarek
