[GRASS-user] r.out.gdal bug? problems with createopt
Markus Neteler neteler at itc.it
Sun Sep 23 11:49:29 EDT 2007
Hi Robert,
it seems to be the same bug as it was found and fixed in v.out.ogr
some days ago by Martin.
I debugged a bit and found that the second part
"PROFILE=BASELINE" isn't passed. It gets lost in
main.c, line 554.
v.out.ogr's main.c (line 249 etc) has a working solution
but my try to port it to r.out.gdal failed (no idea why, should be
rather easy - but it segfaults for me).
So - we are close to a solution :)
Markus
Robert Nuske wrote:
> Hi List,
> I am trying to export a floating point raster into a tiff, BUT without
> writing
> a GeoHeader (no GeoTiff!).
> ( I want to do this rather unusual thing, because the PCI Geomatics
> Software
> has Problems with the Gauss Kruger Projection. It misinterprets a good
> looking GeoTiff and writes only garbage in the GeoHeader of its output.
> But
> if one feeds it just coordinates they line up perfectly.)
> r.out.gdal [...] createopt="TFW=YES,PROFILE=BASELINE"
> writes always a GeoHeader!
> According to the GDAL documentation (http://www.gdal.org/frmt_gtiff.html)
> it
> should not write any Geo-Stuff, if given the option PROFILE=BASELINE.
> I then tested the scripted version
> r.out.gdal.sh [...] createopt="TFW=YES,PROFILE=BASELINE"
> and luckily it behaves and writes a tif without GeoHeader.
> cheers,
>   robert
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
View this message in context: http://www.nabble.com/r.out.gdal-bug--problems-with-createopt-tf4504650.html#a12847602
Sent from the Grass - Users mailing list archive at Nabble.com.
