[GRASS-user] distance from extent to origin cost surfaces
Dylan Beaudette dylan.beaudette at gmail.com
Tue Apr 1 12:15:46 EDT 2008
On Mon, Mar 31, 2008 at 4:57 AM, Glynn Clements
<glynn at gclements.plus.com> wrote:
>  Dylan Beaudette wrote:
>  > > > This is slightly incorrect -- as we are growing the cost surface to
>  > > > compute the perimeter, when we should be shrinking it. However it
>  > > > appears that r.grow cannot use a negative radius.
>  > > create a negative mask, grow that, then invert again:
>  > > r.mapcalc "inv_mask = if(isnull(mask), 1, null())"
>  > > r.grow in=inv_mask out=inv_mask.grown
>  > > r.mapcalc "mask_shrunk = if(isnull(inv_mask.grown), 1, null())"
> > I haven't looked at the source for r.grow -- does anyone know how much effort
>  > it would take so that it could accept a negative "growth radius" ?
>  It would make more sense to add a specific "shrink" flag.
>  I have attached a modified (and untested) version of
>  raster/r.grow2/main.c which implements such a flag.
>  It would be possible to do so with less code duplication (the shrink
>  and grow cases are structurally very similar), but would might make
>  the code harder to understand. I'm not sure which is preferable.
>  Glynn Clements <glynn at gclements.plus.com>
>   * MODULE:       r.grow2
>   * AUTHOR(S):    Marjorie Larson - CERL
>   *               Glynn Clements
>   * PURPOSE:      Generates a raster map layer with contiguous areas
>   *               grown by one cell.
>   * COPYRIGHT:    (C) 2006 by the GRASS Development Team
>   *               This program is free software under the GNU General Public
>   *               License (>=v2). Read the file COPYING that comes with GRASS
>   *               for details.
>  #include <stdio.h>
>  #include <stdlib.h>
>  #include <string.h>
>  #include <grass/gis.h>
>  #include <grass/glocale.h>
>  #define MAX(a, b)       ((a) > (b) ? (a) : (b))
>  static int size;
>  static int count;
>  static int (*neighbors)[2];
>  typedef int metric_fn(int, int);
>  static int distance_euclidian_squared(int dx, int dy)
>         return dx * dx + dy * dy;
>  static int distance_maximum(int dx, int dy)
>         return MAX(abs(dx), abs(dy));
>  static int distance_manhattan(int dx, int dy)
>         return abs(dx) + abs(dy);
>  static void setup_neighbors(double radius, int limit, metric_fn *dist)
>         int i, dx, dy;
>         int n;
>         size = (int) radius;
>         n = size * 2 + 1;
>         neighbors = G_malloc(n * n * 2 * sizeof(int));
>         count = 0;
>         for (i = 1; i <= limit; i++)
>                 for (dy = -size; dy <= size; dy++)
>                         for (dx = -size; dx <= size; dx++)
>                                 if ((*dist)(dx, dy) != i)
>                                         continue;
>                                 neighbors[count][0] = dx;
>                                 neighbors[count][1] = dy;
>                                 count++;
>  static void setup_neighbors_euclidian(double radius)
>         int r2 = (int) (radius * radius);
>         setup_neighbors(radius, r2, distance_euclidian_squared);
>  static void setup_neighbors_maximum(double radius)
>         setup_neighbors(radius, (int) radius, distance_maximum);
>  static void setup_neighbors_manhattan(double radius)
>         setup_neighbors(radius, (int) radius, distance_manhattan);
>  int main(int argc, char **argv)
>         struct GModule *module;
>         struct {
>                 struct Option *in, *out, *rad, *met, *old, *new;
>         } opt;
>         struct {
>                 struct Flag *q, *s;
>         } flag;
>         struct Colors colr;
>         struct Categories cats;
>         int verbose;
>         int colrfile;
>         char *in_name;
>         char *out_name;
>         double radius;
>         int oldval = 0;
>         int newval = 0;
>         char *mapset;
>         RASTER_MAP_TYPE type;
>         int in_fd;
>         int out_fd;
>         DCELL **in_rows;
>         DCELL *out_row;
>         int nrows, row;
>         int ncols, col;
>         int shrink;
>         G_gisinit(argv[0]);
>         module = G_define_module();
>         module->keywords = _("raster");
>     module->description =
>                 _("Generates a raster map layer "
>                 "with contiguous areas grown by one cell.");
>         opt.in = G_define_standard_option(G_OPT_R_INPUT);
>         opt.out = G_define_standard_option(G_OPT_R_OUTPUT);
>         opt.rad = G_define_option();
>         opt.rad->key         = "radius";
>         opt.rad->type        = TYPE_DOUBLE;
>         opt.rad->required    = NO;
>         opt.rad->description = _("Radius of buffer in raster cells");
>         opt.rad->answer      = "1.01";
>         opt.met = G_define_option();
>         opt.met->key         = "metric";
>         opt.met->type        = TYPE_STRING;
>         opt.met->required    = NO;
>         opt.met->description = _("Metric");
>         opt.met->options     = "euclidian,maximum,manhattan";
>         opt.met->answer      = "euclidian";
>         opt.old = G_define_option();
>         opt.old->key         = "old";
>         opt.old->type        = TYPE_INTEGER;
>         opt.old->required    = NO;
>         opt.old->description = _("Value to write for input cells which are non-NULL (-1 => NULL)");
>         opt.new = G_define_option();
>         opt.new->key         = "new";
>         opt.new->type        = TYPE_INTEGER;
>         opt.new->required    = NO;
>         opt.new->description = _("Value to write for \"grown\" cells");
>         flag.q = G_define_flag();
>         flag.q->key         = 'q';
>         flag.q->description = _("Quiet");
>         flag.s = G_define_flag();
>         flag.s->key         = 's';
>         flag.s->description = _("Shrink (grow null areas)");
>         if (G_parser(argc, argv))
>                 exit(EXIT_FAILURE);
>         in_name = opt.in->answer;
>         out_name = opt.out->answer;
>         radius = atof(opt.rad->answer);
>         if (opt.old->answer)
>                 oldval = atoi(opt.old->answer);
>         if (opt.new->answer)
>                 newval = atoi(opt.new->answer);
>         verbose = !flag.q->answer;
>         shrink = flag.s->answer ? 1 : 0;
>         mapset = G_find_cell(in_name, "");
>         if (!mapset)
>                 G_fatal_error(_("Raster map <%s> not found"), in_name);
>         nrows = G_window_rows();
>         ncols = G_window_cols();
>         if (strcmp(opt.met->answer, "euclidian") == 0)
>                 setup_neighbors_euclidian(radius);
>         else if (strcmp(opt.met->answer, "maximum") == 0)
>                 setup_neighbors_maximum(radius);
>         else if (strcmp(opt.met->answer, "manhattan") == 0)
>                 setup_neighbors_manhattan(radius);
>         else
>                 G_fatal_error(_("Unknown metric: [%s]."), opt.met->answer);
>         in_fd = G_open_cell_old(in_name, mapset);
>         if (in_fd < 0)
>                 G_fatal_error(_("Unable to open raster map <%s>"), in_name);
>         type = G_get_raster_map_type(in_fd);
>         out_fd = G_open_raster_new(out_name, type);
>         if (out_fd < 0)
>                 G_fatal_error(_("Unable to create raster map <%s>"), out_name);
>         if (G_read_cats(in_name, mapset, &cats) == -1)
>                 G_warning(_("Error reading category file for <%s>"), in_name);
>                 G_init_cats(0, "", &cats);
>         if (G_read_colors(in_name, mapset, &colr) == -1)
>                 G_warning(_("Error in reading color file for <%s>"), in_name);
>                 colrfile = 0;
>         else
>                 colrfile = 1;
>         if (opt.old->answer && oldval >= 0)
>                 G_set_cat(oldval, "original cells", &cats);
>                 G_set_cat(newval, "grown cells", &cats);
>         in_rows = G_malloc((size * 2 + 1) * sizeof(DCELL *));
>         for (row = 0; row <= size * 2; row++)
>                 in_rows[row] = G_allocate_d_raster_buf();
>         out_row = G_allocate_d_raster_buf();
>         for (row = 0; row < size; row++)
>                 G_get_d_raster_row(in_fd, in_rows[size + row], row);
>         for (row = 0; row < nrows; row++)
>                 DCELL *tmp;
>                 int i;
>                 if (row + size < nrows)
>                         G_get_d_raster_row(in_fd, in_rows[size * 2], row + size);
>                 for (col = 0; col < ncols; col++)
>                         DCELL *c = &in_rows[size][col];
>                         if (shrink)
>                                 if (G_is_d_null_value(c))
>                                         G_set_d_null_value(&out_row[col], 1);
>                                         continue;
>                                 for (i = 0; i < count; i++)
>                                         int dx = neighbors[i][0];
>                                         int dy = neighbors[i][1];
>                                         int x = col + dx;
>                                         int y = row + dy;
>                                         if (x < 0 || x >= ncols || y < 0 || y >= nrows)
>                                                 continue;
>                                         c = &in_rows[size + dy][x];
>                                                 break;
>                                 if (i == count)
>                                         out_row[col] = *c;
>                         else
>                                 if (!G_is_d_null_value(c))
>                                                 if (oldval < 0)
>                                                 else
>                                                         out_row[col] = oldval;
>                                         else
>                                                 out_row[col] = *c;
>                                         continue;
>                                         int x = col + dx;
>                                         int y = row + dy;
>                                                 continue;
>                                                 out_row[col] = opt.new->answer
>                                                         ? newval
>                                                         : *c;
>                                                 break;
>                                 if (i == count)
>                 G_put_d_raster_row(out_fd, out_row);
>                 if (verbose)
>                         G_percent(row, nrows, 2);
>                 tmp = in_rows[0];
>                 for (i = 0; i < size * 2; i++)
>                         in_rows[i] = in_rows[i + 1];
>                 in_rows[size * 2] = tmp;
>         if (verbose)
>         G_close_cell(in_fd);
>         G_close_cell(out_fd);
>         if (G_write_cats(out_name, &cats) == -1)
>                 G_warning(_("Error writing category file for <%s>"), out_name);
>         if (colrfile)
>                 if (G_write_colors(out_name, G_mapset(), &colr) == -1)
>                         G_warning(_("Error writing color file for <%s>"), out_name);
>         return EXIT_SUCCESS;
Thanks for suggesting this Glynn. You are quite correct in that there
is a delicate balance between transparency and efficiency. Before I
make a suggestion, I need a little help understanding this little bit
from the original code:
                                                       ? newval
                                                       : *c;
                                               break;
what exactly is this stanza doing, and why does it contain newval
*and* opt.new->answer ??
Either way, I think that the ability to grow null regions would be a
very useful option-- similar to mask "eroding" functions in R.
If it would help I can submit a feature request for this.
Cheers,
Dylan
