[GRASS-user] Vector not displaying labels from Layer 2
Martin Landa landa.martin at gmail.com
Fri Apr 4 17:25:16 EDT 2008
2008/4/4, Richard Chirgwin <rchirgwin at ozemail.com.au>:
>  I'm running Grass-GIS 6.2, the Ubuntu build from
> http://www.les-ejk.cz/ubuntu/ (for those who previously knew me as a Mac
> user, I'm running Linux at home).
I would suggest you to use switch to grass63.
>  I have a vector that has database links on Layer 1 and Layer 2.
> v.db.connect shows that both connections are active, and v.info correctly
> describes the table linked to either layer.
>  My problem is that I can't get labels from Layer 2 to display. Any
> suggestions?
exact command?
Also note that layer for labels is '1' by default in GRASS 6.2. In
GRASS 6.3 default value of 'llayer' is based on given 'layer' value.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
