[GRASS-user] Another error with wxpython GUI in RC6 - repeatable
geep999 geep999 at yahoo.co.uk
Sun Apr 13 05:30:18 EDT 2008
Hi Martin, Glynn & everybody,
To repeat the problem consistently:
-there is an error if there is no directory called PERMANENT
in a directory below the directory where grass63 -wxpython is run
-creating a directory anything/PERMANENT prevents the problem
i.e. run grass63 -wxpython in $HOME starts OK when directory
$HOME/anything/PERMANENT exists
Cheers, Peter
> Problem solved (accidentally!) - not totally sure how.
> And found a new (to me!) dependency - NumPy.
> 1/ When I started "grass63 -wxpython" the first few times I was in my home
> directory.
> When I got the nasty error messages initially reported I did not have any
> GIS Data.
> Later I copied a GIS Data Directory from another PC into $HOME/MountDoom
> Then:
> cd $HOME/MountDoom
> grass63 -wxpython   (whilst in $HOME/MountDoom)
> No more nasty error messages, instead I got this:
> dad at VMSLACK12_1_RC1:~/MountDoom$ grass63 -wxpython
> Cleaning up temporary files.....
> Starting GRASS ...
> GRASS GUI should be wxpython
>           __________  ___   __________    _______________
>          / ____/ __ \/   | / ___/ ___/   / ____/  _/ ___/
>         / / __/ /_/ / /| | \__ \\_  \   / / __ / / \__ \
>        / /_/ / _, _/ ___ |___/ /__/ /  / /_/ // / ___/ /
>        \____/_/ |_/_/  |_/____/____/   \____/___//____/
> Welcome to GRASS 6.3.0svn (2008)
> GRASS homepage:                          http://grass.osgeo.org/
> This version running thru:               Bash Shell (/bin/bash)
> Help is available with the command:      g.manual -i
> See the licence terms with:              g.version -c
> If required, restart the GUI with:       g.gui wxpython
> When ready to quit enter:                exit
> GRASS 6.3.0svn (MountDoom):~/MountDoom > profile.py:
>     This module requires the NumPy module,
>     which could not be imported.  It probably is not installed
>     (it's not part of the standard Python distribution). See the
>     Numeric Python site (http://numpy.scipy.org) for information on
>     downloading source or binaries.
> 2/ So, I installed this new dependency ;) NumPy.
> Lo and behold, without so much as a ./configure or make, I find that
> grass63 -wxpython is running with a shiny new interface.
> 3/ It seems that launching from within $HOME/MountDoom was somehow the
> trick that got me started,
> and stopped the nasty error messages.
> I note that -wxpython and -tcltk show different Project Locations
> when launched from my $HOME directory.
> -tcltk lists all directories in $HOME in the Project Location box
> -wxpython only lists directory MountDoom in the Project Location box
> Cheers,
> Peter
> Martin Landa-2 wrote:
>> Hi,
>>>  1/ I tried compiling using --with-python=no --with-wxwidgets
>>>  But with svn revision 30941 I get:
>>>  Errors in:
>>>  /home/dad/grass63_release_build/grass63_release/gui/wxpython/vdigit
>>>  In case of errors please change into the directory with error and run
>>>  'make'.
>> now should be fixed in trunk and releasebranch_63, see
>> http://trac.osgeo.org/grass/changeset/30951
>> when you run
>> svn up
>> ./configure ... --with-python=no ...
>> vdigit will be not compiled, i.e. it requires both --with-python and
>> --with-wxwidgets.
>>>  So it seems that to have the wxPython gui I need to have swig
>>> installed.
>> No, swig is need only for compilation of vector digitizer, wxGUI
>> (without digitizer) is installed regardless of any configuration
>> switch.
>> Martin
>> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
View this message in context: http://www.nabble.com/Another-error-with-wxpython-GUI-in-RC6-tp16627913p16656755.html
Sent from the Grass - Users mailing list archive at Nabble.com.
