[GRASS-user] Another error with wxpython GUI in RC6 - repeatable
Peter Gardner geep999 at yahoo.co.uk
Sun Apr 13 10:03:56 EDT 2008
OK now with  releasebranch_6_3 grass63_release 30968.
Cheers, Peter
Martin Landa <landa.martin at gmail.com> wrote: Hi,
I committed this patch to releasebranch_63
http://trac.osgeo.org/grass/changeset/30967
Are you getting the same error now?
Martin
2008/4/13, Martin Landa :
> Hi,
>  2008/4/13, geep999 :
> >  -there is an error if there is no directory called PERMANENT
>  >  in a directory below the directory where grass63 -wxpython is run
> strange I cannot reproduce this error (python 2.4.5, wxpython 2.8.7.1)
>  rm -r /home/martin/.grassrc6
>  ls
>  [nothing]
>  grass630 -wxpython
>  [gui starts -> list of locations/mapsets empty]
>  The patch I sent you didn't help?
>  BTW, can you install also grass_trunk and check if the same error appears?
>  Martin
>  >  geep999 wrote:
>  >  > Hi Martin, Glynn & everybody,
>  >  > Problem solved (accidentally!) - not totally sure how.
>  >  > And found a new (to me!) dependency - NumPy.
>  >  > 1/ When I started "grass63 -wxpython" the first few times I was in my home
>  >  > directory.
>  >  > When I got the nasty error messages initially reported I did not have any
>  >  > GIS Data.
>  >  > Later I copied a GIS Data Directory from another PC into $HOME/MountDoom
>  >  > Then:
>  >  > cd $HOME/MountDoom
>  >  > grass63 -wxpython   (whilst in $HOME/MountDoom)
>  >  > No more nasty error messages, instead I got this:
>  >  > dad at VMSLACK12_1_RC1:~/MountDoom$ grass63 -wxpython
>  >  > Cleaning up temporary files.....
>  >  > Starting GRASS ...
>  >  > GRASS GUI should be wxpython
>  >  >           __________  ___   __________    _______________
>  >  >          / ____/ __ \/   | / ___/ ___/   / ____/  _/ ___/
>  >  >         / / __/ /_/ / /| | \__ \\_  \   / / __ / / \__ \
>  >  >        / /_/ / _, _/ ___ |___/ /__/ /  / /_/ // / ___/ /
>  >  >        \____/_/ |_/_/  |_/____/____/   \____/___//____/
>  >  > Welcome to GRASS 6.3.0svn (2008)
>  >  > GRASS homepage:                          http://grass.osgeo.org/
>  >  > This version running thru:               Bash Shell (/bin/bash)
>  >  > Help is available with the command:      g.manual -i
>  >  > See the licence terms with:              g.version -c
>  >  > If required, restart the GUI with:       g.gui wxpython
>  >  > When ready to quit enter:                exit
>  >  > GRASS 6.3.0svn (MountDoom):~/MountDoom > profile.py:
>  >  >     This module requires the NumPy module,
>  >  >     which could not be imported.  It probably is not installed
>  >  >     (it's not part of the standard Python distribution). See the
>  >  >     Numeric Python site (http://numpy.scipy.org) for information on
>  >  >     downloading source or binaries.
>  >  > 2/ So, I installed this new dependency ;) NumPy.
>  >  > Lo and behold, without so much as a ./configure or make, I find that
>  >  > grass63 -wxpython is running with a shiny new interface.
>  >  > 3/ It seems that launching from within $HOME/MountDoom was somehow the
>  >  > trick that got me started,
>  >  > and stopped the nasty error messages.
>  >  > I note that -wxpython and -tcltk show different Project Locations
>  >  > when launched from my $HOME directory.
>  >  > -tcltk lists all directories in $HOME in the Project Location box
>  >  > -wxpython only lists directory MountDoom in the Project Location box
>  >  > Cheers,
>  >  > Peter
>  >  > Martin Landa-2 wrote:
>  >  >> Hi,
>  >  >>>  1/ I tried compiling using --with-python=no --with-wxwidgets
>  >  >>>  But with svn revision 30941 I get:
>  >  >>>  Errors in:
>  >  >>>  /home/dad/grass63_release_build/grass63_release/gui/wxpython/vdigit
>  >  >>>  In case of errors please change into the directory with error and run
>  >  >>>  'make'.
>  >  >> now should be fixed in trunk and releasebranch_63, see
>  >  >> http://trac.osgeo.org/grass/changeset/30951
>  >  >> when you run
>  >  >> svn up
>  >  >> ./configure ... --with-python=no ...
>  >  >> vdigit will be not compiled, i.e. it requires both --with-python and
>  >  >> --with-wxwidgets.
>  >  >>>  So it seems that to have the wxPython gui I need to have swig
>  >  >>> installed.
>  >  >> No, swig is need only for compilation of vector digitizer, wxGUI
>  >  >> (without digitizer) is installed regardless of any configuration
>  >  >> switch.
>  >  >> Martin
>  >  >> Martin Landa  * http://gama.fsv.cvut.cz/~landa *
>  >  >> _______________________________________________
>  >  >> grass-user mailing list
>  >  >> grass-user at lists.osgeo.org
>  >  >> http://lists.osgeo.org/mailman/listinfo/grass-user
>  >  View this message in context: http://www.nabble.com/Another-error-with-wxpython-GUI-in-RC6-tp16627913p16656755.html
>  >  Sent from the Grass - Users mailing list archive at Nabble.com.
 Yahoo! for Good helps you make a difference
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080413/d1a0fe6e/attachment.html
