[GRASS-user] GRASS 6.3.0RC6 startup error
Thomas Adams Thomas.Adams at noaa.gov
Tue Apr 15 21:38:57 EDT 2008
List:
My apologies; I forgot to run /sbin/ldconfig… all is well.
Regards,
Tom
Thomas Adams wrote:
> List:
> I have built from source various releases of GRASS over the years with
> relatively few problems. However, I just built/installed GRASS
> 6.3.0RC6 on a 64-bit Linux system (compiled with the 64-bit option
> turned on). I did not receive any install errors. GRASS starts-up fine
> until I select "Enter" (following selecting my location and mapset).
> Following this I get a startup error message that reads: "Error
> setting region: child process exited abnormally". The term window
> output looks like this:
> GRASS 6.3.0RC6 (latlong_ohrfc):~/.ssh > Error in startup script: can't
> read "parts(w)": no such variable
> while executing
> "set $parts(w) [expr round($parts(w)/$parts(ewres))*$parts(ewres)]"
> (procedure "MapCanvas::zoom_gregion" line 16)
> invoked from within
> "MapCanvas::zoom_gregion $mon"
> (procedure "MapCanvas::create" line 40)
> invoked from within
> "MapCanvas::create"
> (procedure "Gm::startmon" line 11)
> invoked from within
> "Gm::startmon"
> (procedure "Gm::create" line 79)
> invoked from within
> "Gm::create"
> (procedure "main" line 30)
> invoked from within
> "main $argc $argv"
> (file "/usr/local/grass-6.3.0RC6/etc/gm/gm.tcl" line 541)
> Error in startup script: can't read "parts(w)": no such variable
> while executing
> invoked from within
> invoked from within
> "MapCanvas::create"
> invoked from within
> "Gm::startmon"
> invoked from within
> "Gm::create"
> invoked from within
> "main $argc $argv"
> GRASS in the term window operates fine with command line input, but
> the tcltk interface is DOA. What's interesting is that the tcltk
> output window comes up and the medieval map slash window displays, but
> won't go away until I click on the "OK" button which displays the
> error message.
> Any ideas what's going on? I have 6.3 cvs on a different machine that
> compiled & runs fine.
> Regards,
> Tom
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL:	thomas.adams at noaa.gov
VOICE:	937-383-0528
FAX:	937-383-0033
