[GRASS-user] LOS, Fresnel Zones, Multi-Line wave propagtion and GHz communications
Moritz Lennert mlennert at club.worldonline.be
Thu Apr 17 09:59:22 EDT 2008
On 17/04/08 12:05, Peter Hopfgartner wrote:
> Dear GRASS community,
> I would like to simulate the strength of a signal emitted from an
> antenna and received by a receiver.
> As a first approach r.los gives a good start. Anyway, more accurate
> results could be  obtained by  taking obstruction in the first Fresnel
> Zone into account. Finally, having a way to calculate the impact on
> indirect paths/reflections, should lead to a reasonably accurate signal
> strength map.
> Did anybody work on some of these issues, possibly in combination with
> GRASS? Is there a good starting point for the calculation of the
> obstruction within the first Fresnel Zone.
I don't really understand what you are speaking about (i.e. am
completely incompetent in this field), but would v.net.visibility be
something for you ?
Moritz
