[GRASS-user] Command completion in wxpython-GUI: is it possible(?) + an issue with the EPSG file browser.
Martin Landa landa.martin at gmail.com
Thu Apr 17 18:30:19 EDT 2008
2008/4/17, Nikos Alexandris <nikos.alexandris at felis.uni-freiburg.de>:
> Dear wxpython developers,
>  is it possible to add command completion in the new GRASS-GUI?
sure, one of TODO's:-)
http://grass.osgeo.org/wiki/WxPython-based_GUI_for_GRASS#Roadmap
>  Another issue with the "location wizard":
>  location wizard > next> select EPSG code of coordinate system > Browse:
>  in the "choose EPSG codes file" window the browser refuses to show all
>  files in the directory /usr/share/proj as instructed.
>  Manual typing epsg works fine and I can read the epsg file.
now fixed in trunk,
http://trac.osgeo.org/grass/changeset/31026
Originally file dialog pointed to 'root directory', but anyway I
figured out that loading other files then 'epsg' fails, since slightly
different file structure. I will try to fix it ASAP.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
