[GRASS-user] Command completion in wxpython-GUI: is it possible(?) + an issue with the EPSG file browser.
nikos.alexandris at felis.uni-freiburg.de nikos.alexandris at felis.uni-freiburg.de
Thu Apr 17 20:08:14 EDT 2008
On Fri, 18 Apr 2008 00:30:19 +0200
 "Martin Landa" <landa.martin at gmail.com> wrote:
> Hi,
> 2008/4/17, Nikos Alexandris
> <nikos.alexandris at felis.uni-freiburg.de>:
> > Dear wxpython developers,
> >  is it possible to add command completion in the new
> GRASS-GUI?
> sure, one of TODO's:-)
http://grass.osgeo.org/wiki/WxPython-based_GUI_for_GRASS#Roadmap
> >  Another issue with the "location wizard":
> >  location wizard > next> select EPSG code of coordinate
> system > Browse:
> >  in the "choose EPSG codes file" window the browser
> refuses to show all
> >  files in the directory /usr/share/proj as instructed.
> >  Manual typing epsg works fine and I can read the epsg
> file.
> now fixed in trunk,
> http://trac.osgeo.org/grass/changeset/31026
> Originally file dialog pointed to 'root directory', but
> anyway I
> figured out that loading other files then 'epsg' fails,
> since slightly
> different file structure. I will try to fix it ASAP.
> Martin
Superb!
Cheers,
Nikos
