[GRASS-user] problem with r.li. modules-Charakter Encoding?
Martin Besta grasskonference at googlemail.com
Sat Apr 19 08:50:51 EDT 2008
Hi all,
I have noted one little problem with r.li. modules, when trying to use
overlayed vector map as sampling areas. As example, r.li.edgedensity writes
back this message:
r.li.patchnum map=r1953_10m na landuse conf=pokus1953 output=pokus1953patchnum
Illegal filename. Character <ï> not allowed.
Can't open header file for [(Qï·PQï· ́¿ in (null)]
CHILD[pid = 11280]: unable to open (Qï·PQï· ́¿ mask ... continue without!!!
CHILD[pid = 11279]: unable to open (Qï·PQï· ́¿ mask ... continue without!!!
CHILD[pid = 11278]: unable to open (Qï·PQï· ́¿ mask ... continue without!!!
CHILD[pid = 11277]: unable to open (Qï·PQï· ́¿ mask ... continue without!!!
CHILD[pid = 11276]: unable to open (Qï·PQï· ́¿ mask ... continue without!!!
CHILD[pid = 11275]: unable to open (Qï·PQï· ́¿ mask ... continue without!!!
CHILD[pid = 11274]: unable to open (Qï·PQï· ́¿ mask ... continue without!!!
CHILD[pid = 11272]: unable to open (Qï·PQï· ́¿ mask ... continue without!!!
CHILD[pid = 11271]: unable to open (Qï·PQï· ́¿ mask ... continue without!!!
CHILD[pid = 11270]: unable to open (Qï·PQï· ́¿ mask ... continue without!!!
I guess, this can be caused with incorretct character encoding (my current
settings is ISO-8859-2), but no attempt to change it was succesfull (only
the error message changed in other "not allowed charakter"). I tryed UTF-8,
Windows-1250 and others.
The same vector map, used as sampling area as whole map did works. The
vector map contains this columns types:
INTEGER|cat
INTEGER|CISLO
CHARACTER|KULTURA
DOUBLE PRECISION|PLOCHA
DOUBLE PRECISION|NOVA_AREA
INTEGER|landuse
There is no special character, such as š,ě,í,ö,ä in columns
The second problem with r.li modules is, that I cannot calculate any indice
on 1 m resolution raster with any r.li module. The same, 10 m resolution
raster goes great...is 1 m resolution supported by r.li modules?
Thanks for your helpful answers
Martin
View this message in context: http://www.nabble.com/problem-with-r.li.-modules-Charakter-Encoding--tp16782731p16782731.html
Sent from the Grass - Users mailing list archive at Nabble.com.
