[GRASS-user] add columns for x and y coordinates to vector db
Otto Dassau otto.dassau at gmx.de
Wed Apr 23 02:10:40 EDT 2008
Hi Brandon,
On Tue, 22 Apr 2008 22:22:52 -0700
"Brandon M. Gabler" <bgabler at email.arizona.edu> wrote:
> I have searched the archives, but cannot seem to find the answer.
> I have a vector file, with 700 sites. I want to add columns for
> x_coord and y_coord (or easting and northing, or whatever), so that
> the columns represent the centroid coordinates of each site in the
> vector database. So, for CAT #1, I want the column 'easting' to
> update with the easting of CAT #1, and the column 'northing' to
> update with the northing for CAT #1, and so on for all CAT numbers in
> my file. I'm sure there is an easy script for v.db.update, but wanted
> to check with the list before reinventing the wheel. Has anyone
> created a script for such a thing, or is there a command within GRASS
> that I'm missing?
you can use v.db.addcol to create two new attribute columns for x and y and then
use v.to.db with the option 'coor'.
regards,
 Otto
> Thanks,
> Brandon
