[GRASS-user] missing dbf table for point theme
Markus Neteler neteler at osgeo.org
Thu Apr 24 11:14:24 EDT 2008
On Thu, Apr 24, 2008 at 5:03 PM, christian Brandt
<chrisbrandt74 at hotmail.com> wrote:
>  Dear list,
>  I imported points from ascii table into GRASS 6.3 ORC5. Now I would like to assign values to these points. So doing the v.db.connect command GRASS tells me that there is no table for this layer.
Did you use the "column" parameter?
What does
v.info -c yourmap
say?
Markus
>  Besides, using the v.db.addtable command to add an attribute table to the layer the message appears that there is already a table linked to the layer.
>  What to do now?
>  Regards
